Hi, I’m trying to setup the following gauges but am having issues (some might be bugs?). I’m using a customized Pole Position dash. I’m worried these gauges do not work with Hondata (just like how Hondata does NOT send A/F and Oil Pressure via Bluetooth).
- Speedometer:
- Gauge types: 1. Indicators > Arc Gauge, and 2. Text Gauge
- Data source: Engine/ECU Inputs > Vehicle Speed
- Min/Max for range, warning and critical levels: 0-199.999
- Scale Automatically to Vehicle Max Speed = Off
- Issue: gauge reads 0 at all times
- Gear Selector:
- Gauge types Text Gauge
- Data source: Calculated Values > Gear (Master Speed, RPM, Gear Ratio)
- Min/Max range for range, warning and critical levels: -2-8, 0-100, 0-100
- Issue: gauge reads N or R all the time. I suspect this issue is a result of the speedometer issue.
- Boost Gauge:
- Gauge type: Test Gauge
- Data source: Calculated Values > Boost (Psi)
- Min/Max range for range, warning and critical levels: I believe -30 - 50 for all.
- Issue: Gauge reads incorrectly (was showing -9.4 while Kpro was reading -21.1. I tried Engine/ECU Inputs > Manifold Absolute pressure, but with the car off, i was 3 when it should be reading 0. I will test it again later today with the car running.
Can anyone confirm Realdash can display speed and gear selector from a KproV4? And if it can, is there anything obviously wrong with the setup above?
