Hi all. My question is, how does realdash calculate the range?
via the realdash can, I send a signal of 0 - 100 equivalent to the percentage of filling of the fuel tank (Target ID 170), is this correct? or do I have to send the number of liters in the fuel tank?
This is correct. In addition set the fuel capacity in the Garage to correct value and remove the input mapping to Fuel Level from ‘Settings->Units & Values->Input Mapping’.
If i am going to change the fuel level from calculated value to input value ( actual value from can bus), is this situation will going to change other parameters ( such as fuel consumptions)?
