Hello,
I have found a list of OBDii PIDs that I want to use to extend the standard OBDii protocol inputs in Realdash, but I realy don’t know where to start and how to edit or create a cloned XML file to add these PIDs.
Also: is it possible to add an “input folder” in Realdash? When I add a gauge and go to input & values, then tap on the input, I can see a list where I can choose form Engine Inputs, Transmission, OBD Specific inputs, etc. Is there a way to add a “folder” that shows up there with my specific PIDs and/or favorites, so I don’t have to search every “folder” to get the right input?
Ok, this is the list I found, but I don’t know how to get this in the XML file, so Realdash can translate this into gauges.
PID PID_Name Calculation_Formula Result Text BytesInResponse StartFromByte BytesForCalculation
1A80 Reading Identification Code FIAT drawing number 61 0 11
1A80 Reading Identification Code HW number 61 11 11
1A80 Reading Identification Code HW version 61 22 1
1A80 Reading Identification Code SW number 61 23 11
1A80 Reading Identification Code SW version 61 34 2
1A80 Reading Identification Code Homologation number 61 36 6
1A80 Reading Identification Code ISO code 61 42 5
1A80 Reading Identification Code Tester code 61 47 10
1A80 Reading Identification Code Production date 61 57 4
1A91 FIAT drawing number FIAT drawing number 11 0 11
1A92 HW number HW number 11 0 11
1A93 HW version HW version 1 0 1
1A94 SW number SW number 11 0 11
1A95 SW version SW version 2 0 2
1A96 Homologation number Homologation number 6 0 6
1A98 Tester code Tester code 10 0 10
1A99 Production date Production date 4 0 4
2101 Injection control unit X&0b00000001 X=0b00000000 Programmed 1 0 1
2101 Engine startup X&0b00000010 X=0b00000000 Allowed 1 0 1
2101 Universal code X&0b00000101 X=0b00000101 Received 1 0 1
2101 Injection control unit X&0b11111111 X=X Not programmed 1 0 1
2101 Engine startup X&0b11111111 X=X Not allowed 1 0 1
2101 Universal code X&0b00000101 X=0b00000001 Not received 1 0 1
2101 Universal code X&0b11111111 X=X Not enabled 1 0 1
2103 Odometer X0.1 km 3 0 3
2108 Number of overrevs X1 1 0 1
2109 Max. eng. speed counter X10 msec. 2 0 2
210A Maximum engine speed X40 Rpm 1 0 1
210B Number of rewrites X1 1 0 1
210C Odometer at last rewrite X0.1 km 3 0 3
2121 Cyl. 1 fuel correct. (X<0x8000) ? X0.01 : (X-0x10000)0.01 mm3/inject2 0 2
2122 Cyl. 2 fuel correct. (X<0x8000) ? X0.01 : (X-0x10000)0.01 mm3/inject2 0 2
2123 Cyl. 3 fuel correct. (X<0x8000) ? X0.01 : (X-0x10000)0.01 mm3/inject2 0 2
2124 Cyl. 4 fuel correct. (X<0x8000) ? X0.01 : (X-0x10000)0.01 mm3/inject2 0 2
2125 Cyl. 5 fuel correct. (X<0x8000) ? X0.01 : (X-0x10000)0.01 mm3/inject2 0 2
2130 Engine speed X0.25 Rpm 2 0 2
2131 Vehicle speed X/128.0 km/h 2 0 2
2132 Cruise lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2132 Cruise lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2132 Cruise lamp X&0xFFFF X=X Flashing 2 0 2
2133 Glow plugs lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2133 Glow plugs lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2133 Glow plugs lamp X&0xFFFF X=X Flashing 2 0 2
2134 Water temperature w. lamp X&0b0000000000000001 X=0b0000000000000001 Off2 0 2
2134 Water temperature w. lamp X&0b0000000000000010 X=0b0000000000000010 On2 0 2
2134 Water temperature w. lamp X&0xFFFF X=X Flashing 2 0 2
2135 Oil pressure w. lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 02
2135 Oil pressure w. lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2135 Oil pressure w. lamp X&0xFFFF X=X Flashing 2 0 2
2136 Water in fuel filter lamp X&0b0000000000000001 X=0b0000000000000001 Off2 0 2
2136 Water in fuel filter lamp X&0b0000000000000010 X=0b0000000000000010 On2 0 2
2136 Water in fuel filter lamp X&0xFFFF X=X Flashing 2 0 2
2137 Power-latch duration X1 msec. 2 0 2
2139 Failure lamp X&0b0000000000000001 X=0b0000000000000001 Off 2 0 2
2139 Failure lamp X&0b0000000000000010 X=0b0000000000000010 On 2 0 2
2139 Failure lamp X&0xFFFF X=X Flashing 2 0 2
213D Brake pedal status X&0b00010000 X=0b00010000 Pressed 1 0 1
213D Clutch pedal X&0b00000001 X=0b00000001 Pressed 1 0 1
213D Brake contact 2 X&0b00100000 X=0b00100000 Pressed 1 0 1
213D Accelerator pedal X&0b00000010 X=0b00000010 Accelerator potent. track 11 0 1
213D Brake pedal status X&0b11111111 X=X Released 1 0 1
213D Clutch pedal X&0b11111111 X=X Released 1 0 1
213D Brake contact 2 X&0b11111111 X=X Released 1 0 1
213D Accelerator pedal X&0b11111111 X=X Accelerator potent. track 2 1 0 1
213E Accelerator pedal (X100)/65535 % 2 0 2
213F AD/C accelerator posit. 1 X0.1 mV 2 0 2
Thank you in advance.
