How to change from 000 to the correct km on the car’s original speedometer
Garage, tap at the top where it usually says “My super car” and the option should come up. You might get a mile difference in the long run. I’ve noticed every 100 miles I’m like 2-4 under. I can’t figure out why.
thank you very much, thank you very much
Rim diameter? Does it calculate milage by the ecu or by gps?
Honestly, I don’t know. My tire information is right and my fuel tank is correct in the sense that I used the max capacity.
Currently the new device I’m using has no GPS, but it’s updating the mileage. I haven’t done a check to see how off it is.
Odo- and tripmeters are updated based on speed input. It can be from ECU or from GPS, depending on what you have selected in Settings->Units & Values->Speed Source.
