How to connect, Bluetooth
Here are the most common steps to connect to Bluetooth ELM327 adapter.
If you have created connections that do not work, you may want to clear RealDash app data, or uninstall/install.
  1. Turn Bluetooth on from your device and pair your ELM327 adapter with your device.
  2. Open RealDash, on first start select language, and then go to ‘Garage’
  3. Tap vehicle door and then the instrument cluster. Tap ‘Add’ on connection list
  4. Select ‘OBD2->Bluetooth->“device name”->’ until you are in connection settings page.
  5. Optionally you can check vehicle configurations from ‘Select Vehicle’ button, or leave it as ‘Generic SAE-compatible vehicle’.
  6. Tap upper left corner ‘Done’
  7. Exit garage back to dashboard.
RealDash will connect to your adapter in a few seconds.
Greetings, I have tried this method to connect my phone to OBD2, initially it connected but didn’t work then it disconnected (there was a PID check notification), and connected again and didn’t work again, and so on, can you provide a solution?
If it says “Checking PID support” and then re-connects, it means that RealDash does not understand the reply from your vehicle. Your vehicle may need some specific header to set on that we are not aware of.
