how i can connect it to unichip ecu
It has been a long time since we last worked with Unichip, but it should connect with same steps as any other connection in RealDash. Hope this helps:
USB serial connections are available in Android/Windows/Linux versions of RealDash. Apple does not allow generic serial connections with iOS.
If you have created connections that do not work, you may want to clear RealDash app data, or uninstall/install.
- Attach the USB cable to your vehicle and device. If needed, use appropriate USB-OTG adapter.
- On first run, Android device should ask for permission to use the USB device.
- On RealDash, go to the Garage and tap vehicle door and then the instrument cluster. Tap ‘Add’ on connection list
- Select ‘Unichip->Serial/USB->ECU serial device name->’
- Select correct baud rate for your ECU. Typically 115200.
- Tap upper left corner ‘Done’
- Exit garage back to dashboard.
RealDash will connect to your ECU in a few seconds.
