How to connect to BeamNG
[Localhost connections on Windows 10/11]( Localhost connections on Windows 10/11 - General / Bugs and troubleshooting - RealDash Forum)
  1. Connect device running RealDash into same local network where game is running.
  2. Verify that you are not blocking UDP traffic or ports on your network router.
  3. Start RealDash, go to the Garage and setup new connection to ‘Racing Simulator->BeamNG Drive’.
  4. Note the Port and IP address that is shown in RealDash connection settings.
  5. Start BeamNG.drive and go to Options->Other.
  • Enable ‘OutGauge UDP protocol’
  • Address: REALDASH DEVICE IP or leave to 127.0.0.1 if RealDash is running on same machine with BeamNG.
  • Port: Use same port as in RealDash connection settings (default is 4444)
  • Uncheck ‘MotionSim enabled’ option, or use different port. Otherwise MotionSim packages will intervene with OutGauge data.
BeamNG Drive will start sending the telemetry data when the game starts.
it didn`t work !!!
Ok, I have not tested BeamNG.drive for a long time. Does anyone know if something has changed in its telemetry output?
