How to connect to Ecumaster EMU
If you have created connections that do not work, you may want to clear RealDash app data, or uninstall/install.
  1. Enable Bluetooth data stream broadcast from EMU tuning software.
  2. Turn Bluetooth on from your device and pair EMU Bluetooth module with your device.
  3. Open RealDash, tap center top to open the top menu, and then select ‘Garage’
  4. Tap vehicle door and then the instrument cluster. Tap ‘Add’ on connection list
  5. Select ‘Ecumaster EMU->Bluetooth->“device name”->’ until you are in connection settings page.
  6. No need to change the connection settings, Tap upper left corner ‘Done’
  7. Exit garage back to dashboard.
