Configure the serial output on KMS tuning software. Note the set baud rate.
RealDash Configuration:
- Attach the USB cable to your vehicle and device. On Android, use appropriate USB-OTG adapter.
- Open RealDash, on first start select language, and then go to ‘Garage’
- Tap vehicle door and then the instrument cluster. Tap ‘Add’ on connection list
- Select ‘KMS MP25 and MD35)->Serial/USB->serial device name->’
- Select baud rate to same value as configured into KMS ECU.
- Tap upper left corner ‘Done’
- Exit garage back to dashboard.
