How to connect to Wreckfest 2
If you are running Windows version of RealDash on same local machine with the game, see this forum post first:
Localhost connections on Windows 10/11 - General / Bugs and troubleshooting - RealDash Forum
  • Have both, game and RealDash connected on same local network.
  • Find the IP address of computer running Wreckfest 2 and RealDash. If they are both running on same machine, 127.0.0.1 can be used as IP address.
  • Enable and configure telemetry on Wreckfest 2
    • Find game save folder, typically starts with .. Documents\My Games\Wreckfest 2\
    • open telemetry\config.json file and edit
      • “enabled” to 1
      • “ip” to ip address of a device running RealDash. If both are in same machine, use 127.0.0.1
      • Note the “port” setting as it needs to be entered into RealDash connection settings.
  • Start RealDash, go to Garage, open vehicle door and tap the instrument cluster.
  • Add new connection, Select “Racing Simulator->Wreckfest 2”
  • Enter the IP address of the computer running the game
  • Enter the port number specified in game /telemetry/config.json
  • Return to the dashboard and RealDash will connect to your Wreckfest 2 session.
