Unfortunately I never received the Bluetooth specifications from Hondata, and therefore Hondata Bluetooth does not work with iOS. It works fine on Android and Windows though.
The Issue is not the protocol specification, as it is exactly the same regardless of the OS RealDash is running on. The problem is that Hondata did not provide Bluetooth LE service tags required to connect to send/receive data on Bluetooth LE device with iOS. Also, they did not provide any test device for us to try to figure it our by ourselves.
Do you have actual information about this or are you just throwing ideas? You sure understand that its impossible to develop the support without actual device to test with, or somebody volunteering to test, which can be a real pain in iOS.
If you have real information and don’t want to share it here, send me an email.
