Thank you for all your involvement in the forms. your the best. I only have 2 calculations that are stopping me from running as my primary cluster if you could help that would be great.
I use USA gal and MPH
I was able to get the P,R,N,D working I have a manual mode in my car that lets me shift gears. When i try to cycle thru the gears the numbers are not counting up. I would like to know when I go into sport mode so I can have it change the display.
Mine is an automatic but a lot of the stuff can be moved or at least use to find where to start. This site has also helped me track down some CAN ID’s CarPC Install
If you do not write anything to CAN bus, change of bricking your car is fairly low. But of course its wise to be careful as when you tap into CAN bus, its very easy to mess it up.
I have ran into a bit of a roadblock. I cant read my can bus right now. I think I have a module that is having an issue that I have to find before I can make anymore progress.
I was finally able to get back running. I’m still running into issues with trying to get fuel and Speed and work with MPH not KPM to work. Any help would be great. This is a dump from the obd2.
@Cableline01
Hello guys just started working on a project but need too much help .
First question :
how you are launchin Realdash on pi5 ? Android or which system?
Also i have a Nissan Patrol swapped on M57d30 with EDC15 and i’m blocked didn’t know how to convert the results can you help ?
