how to make it read PRND with the dashbox?
Write value to ‘Transmission->Shifter Position’ (ID 141) as:
- 5 = D
- 6 = N
- 7 = R
- 8 = P
If you are connected to CAN via DashBox, you can use CAN XML ‘enum’ to convert any value to text.
Can you write a example xml code please thank you
value name=“Gear Number” startbit=“12” bitcount=“4” conversion=“V” enum=“92:P,108:R,124:N,140:D”>
This is for a BMW but this is the concept
Thank you for your reply I already managed to make xml after reading on GitHub the issue I was having was trying to do with shifter position id 141 it didn’t work so I have success with gear transmission Id 139
