I’m doing a Realdash conversion into my 06 Mustang/Tesla swap and want to shut off the oil light in the Realdash starter dash. Is it possible. I tried setting all the settings to zero but that did not work.
I didn’t find a dash called “starter” maybe you mean the default? You could go to edit mode and delete the gauge or in inputs & sources change data source to none.
Yes I meant default. Thank you it worked out fine. Click on oil light and hit delete. I was making it too complicated.
