Hi,
I’m trying to add a custom XML file following this doc. It says that I can specify OBD Header, also it says that once header is set it will be used for the next commands as well. How do I reset header for the next commands?
I’m trying to add fuel level, this PID works in Torque Pro app for my car:
PID: 2129
Equation: ((A*50)/100)
OBD Header: 7c0
This is what I’ve got so far: https://github.com/vkolotov/RealDash-extras/blob/master/OBD2/realdash_obd2_toyota_jdm_generic.xml
Basically the change is this:
<command send="2129" skipCount="25" targetId="201" conversion="100*(((A*50)/100)/65)" ></command> <!-- fuel level -->
How can I make sure the next command does not use any header?
Cheers
