mm-hmm
So,
- connect the AlfaObd, select the speed sensor to be displayed.
- I turn on the CAN H and the CAN L from the ObDIi to MCP2515(Arduino) module
- turn the Arduino on and see the packages being request and response
Is it?
mm-hmm
So,
Is it?
not. not really
It should look in parallel, so we do not block communication with the computer, but simply observe.
I hope that you understand which assembly should precede the MCP 2515, as I did not indicate this in the diagram.
study the materials on my blog.
ps:
need a translator))))
Yesss… thank you so much…
I really understand this connections.
In follow weeks I will try this.
i hope everything’s all right
Thank you again …
This is not announced yet, but in next release of RealDash you can use OBDLink adapters (http://obdlink.com) as direct CAN adapters too, so if you are considering buying an CAN adapter, OBDLink MX Bluetooth would be an good option.
Wow! it’s good!
