I have a question:
Hello, I have a question: Did they have a board on which all the elements could work?? As seen on the dashboard stomolator Thank you
Whether the gauges will work or not depends on what information is received from your vehicle. Not all connections send all the information that RealDash supports.
Edit: Text removed, forum is English only.
Thanks for your attention and reply. But my question was why there are no left and right turn signals, short and long lights, as on the stimulator on the dashboard.
Assuming that you are using OBD2 connection type, its not going to happen easily. See this forum post for more information:
OBD2 indicators, fuel level and gear - Connectivity / OBD2 - RealDash Forum
