Hi all.
Have done a lot of research and decided to give this a shot on my bike. I have a bunch of old nano units sitting around, so thought I’d have a play while the Every boards turn up
It’s not a problem, exactly, but what would you expect to see when viewing the realdash_can.ino examples serial monitor in ide. Text comes through fine, the rest is ocassional numbers, letters and then little squares where there should be a character but isn’t.
Baud rates are set correctly- processor etc appears to be set correctly, I’m guessing it’s just a format that needs conversion or that the serial monitor can’t read?
Thanks all ![]()
