Hi All
I am still working on a few Parameters and could need some hints.
The car is a Opel Adam (Similar to Corsa). Some of the GM Parameters i found in the CAN Template work. For example, VSS, RPM, CLT work perfectly fine.
But i can’t really find the ID and Bytes for AFR and Fuel Gauge.
Any hint or help is appreciated
Currently the AFR just sits at 22 and won’t budge
And the Fuel gauge seems to jump from 1/8th while the tank is filled 25%
to
3/8 when the tank is at 100%
