Jani, Thought I would post here because you probably get too many emails and this is probably better for you and others maybe having the same issue.
I’m still having a bit (no pun intended) of an issue here. RealDash is reading the Canbus input fine but it seems my xml is wrong to have it work the indication images. I eliminated Park, Ready, Wait, below to make it a shorter message for anyone…
d |= (Park << 0); // bit 0 if Park==true, bit 0 will be set 1, and vice versa
d |= (Wait << 1); // bit 1
d |= (Ready << 2); //bit 2
d |= (Drive << 3); //bit 3
d |= (Reverse << 4); //bit 4
d |= (Neutral << 5); //bit 5
// send CAN frame
CAN_message_t frame;
frame.id = 0x201;
frame.len = 8;
frame.buf[0] = 0x00;
frame.buf[1] = 0x00;
frame.buf[2] = 0x00;
frame.buf[3] = 0x00;
frame.buf[4] = 0x00;
frame.buf[5] = 0x00;
frame.buf[6] = 0x00;
frame.buf[7] = d; // Bits in this byte indicate IO pin states with only one of RND allowed:
Can1.write(frame);
Drive= 0x201= 00 00 00 00 00 00 00 08
Neutral= 0x201= 00 00 00 00 00 00 00 20
Reverse= 0x201= 00 00 00 00 00 00 00 10
