Hello, I have a problem importing the dash into the application, I noticed that on all my devices it is not accepting these personalized ones. I enter the gallery when loading from file select the file I want, but it doesn’t appear on the loading page so I can select the file, anyone else having this problem?
From Android 10 the file security prevents RealDash from accessing the user files directly. You need to use the ‘Import’ option to copy the dashboard file into all private filesystem before it can be used. After it has been imported, it should appear on the list.
