Hi, I am new here. I really like the APP but I found when I use different skin the speed and the gear are wrong. When I park, the gear is 1 and speed is 1 on Audi skin. But the speed is 7 on Benz skin. Could you tell me how to fix it? Thanks!
Welcome to the forum.
I don’t understand how the speed could show different values with different dashboards as the input system is completely separate from the dashboards.
Are you using GPS as a speed source? Maybe you can try to change it to ECU Speed sensor from Settings->Units and Values. Sometimes a poor quality GPS signal can cause slight drift speed even when you are parked.
I am using Bluetooth OBDII and default setting.
Could you check that speed source is set to ‘ECU Speed sensor’?
- Go to Settings->Units & Values to check this setting.
