Increased fuel consumption after installing a digital panel with realdash
Is it possible to change some configuration in realdash and this configuration changes the engine’s fuel consumption for more consumption, because after I installed the digital panel with realdash the fuel consumption increased, I use arduino my car does not have a CAN network, the possibility of some configuration in realdash having increased the fuel consumption
Unless you send a command, no it shouldn’t increase fuel consumption. Are you sure it’s increased and that the formula isn’t incorrect? I believe on a different post they’ve mentioned that fuel level is calculated differently by every car manufacturer.
There is one related setting in Garage:
Garage->Tap Vehicle Name->Fuel Consumption Correction Factor
thanks thanks thanks
Are you saying that the engine is consuming more fuel, or the measurement in Realdash?
without understanding anything, more doubts ???
hanks thanks thanks, hanks thanks thanks
