Indicator Cluster, does not accept the minimum value, operation continues as if it were at zero.
Do you mean range minimum at Input & Values? Tried that but seems to work for me.
Yes in Input & Values. For me the minimum value has no effect.
I tried Indicator cluster with RPM input having a range of 3000-8000, and first indicator on cluster lits up at 3000. Could give more details of your test setup?
I tested it again, and I saw that the critical level color change does not correspond to the Value range proportion:
Ok, will check again.
