Hey guys,
I’ve tried to read a single bit, but I do not know how RealDash is counting…
Tried every different ways, but still no luck… RPM was running totally fine at the first shot!
My bit is in ID 21A, ID is 3 bytes long, I’m counting the bytes 0,1,2 , at the most right bit in byte 0 is my high beam… So I used:
/frame>
Also Startbit=“7” is not working…
Can someone give me a hint…?
Greets, Clubbi
Seems not a problem with the xml…
I’ve uploaded a filter to the CAN-USB-Analyzer, in the Chinese software it shows me ID 0x0A5 and 0x21A like expected…
But in RealDash, the CAN-Monitor only shows me ID 0x0A5…?
So RealDash does not read the 0x21A frame? Is this device/vehicle something that I could get my hands on to try?
Yeah it seems like that…
If something like a TeamViewer-Session will help you, let me know…
PEAK Can-Explorer and hardware available.
Kind regards,
Martin
