Inport Extport Triggers
Hello
plase add possibility: inport and export triggers in edit mode
P/S
now i use combine skin and after delete page but all time some triggers is miss and i all time repair
regards
Falcon
This is not without issues. All triggers and actions refer to the items on the dashboard and usually importing them from another dashboard will make them useless for another dash.
What I recommend is that make a empty dashboard with only the triggers and actions you commonly use and then use the combine option for the dashboards.
If your triggers and actions are something that you really use all the time, consider using Global triggers and actions from Settings->Application. Those are imported/exported with Garage settings.
global triggers i use but i get some problem with specific value - some time not work: need test and time
today i use clear skin with only triggers - after combine he all present - awesome !!!
Best regards
Falcon
Exactly three years have passed since the request to add import/export! A new achievement!
