I am displaying fuel level as a percentage. I would like it to be green when it’s between 50 and 100, yellow between 25 and 50 and red between 0 and 25.
I see examples of the value is increasing but how do I set it if the values are decreasing?
In edit mode, select your gauge and tap ‘Input & Values’ in top menu. Here set:
range: 0 - 100
warning level: 50 - 120
critical level: 25 - 120
Then set the colors to normal, warning and critical levels in Look’n Feel.
How these levels work, is that gauge will enter into warning or critical level if its value is below the left value OR above the right value. If gauge is not in warning or critical, it is set to be in ‘normal’ level.
thank you so much… that did the trick.
Are there any updates to when the new version for windows will be released?
Hopefully today or tomorrow, still some testing to do.
