We hack ID instant Fuel Consuplton in car Renault / Nissan
Now we calculate this code - every 3 seconds
private void receive(byte[] data) throws IOException {
// spn.append("receive " + data.length + " bytes\n");
for (int i = 0; i < data.length; i += 16) {
int id = data[i + 4] + data[i + 5] * 256;
// if (MainActivity.FiltrNumber != 0 || MainActivity.FiltrNumber == id) {
if (data[i + 4] == 0x6a && data[i + 5] == 0x06) {
// SpannableStringBuilder spn = new SpannableStringBuilder();
// spn.append(HexDump.dumpHexString(data)).append("\n");
MainActivity.Consumption = data[i + 11];
NewTime = System.currentTimeMillis();
long deltaTime = NewTime - OldTime;
if (deltaTime > 2500) {
int delta = MainActivity.Consumption - MainActivity.Consumption_old;
if (delta < 0)
delta += 256;
float con = delta / 10f * (1000f / deltaTime) * 3600f / 1000f;
String s;
if (MainActivity.speed > 15.0f) {
con = con * (100f / MainActivity.speed);
s = "cons = " + String.format ("%.3f", con) + "L/100km" + "\n";
else {
s = "cons = " + String.format ("%.3f", con) + "L/hour" + "\n";
// spn.append(s);
receiveText.append(s);
MainActivity.Consumption_old = MainActivity.Consumption;
OldTime = NewTime;
// try {
// s += "\n";
// MainActivity.fOut.write(s.getBytes());
// } catch (IOException e) {
// e.printStackTrace();
else if (id == 535) { //speed
MainActivity.speed = (data[i + 11]*255*255 + data[i+ 12]*255 + data[i + 13])/39500f;
if (MainActivity.FiltrNumber == 0 || MainActivity.FiltrNumber == id) {
if (MainActivity.RecordFlag) {
try {
MainActivity.fOut.write(data, 0, data.length);
can ID 66A offset=“3” we accumulate the value difference every for example three seconds -
please add this function in XML as ENUM
regards
Slava
