Is it necessary to connect a 120-ohm resistor to the CAN analyzer device?
That depends on resistance of the CAN lines.
Measure the resistance across CAN_H and CAN_L with the power off.
- If you read ~60 ohms → already terminated, no need for another resistor.
- If you read ~120 ohms or more → you may need to add one.
I solved the problem and was able to run it on Motec M84
