I Have a LINK ECU outputting CAN Data to realdash at 50hz but my RPM needle moves around very slowly and sluggishly, like the values are smoothed out or something. i am using the screamer dash by the way. is it possible to make the RPM needle move very quickly and show the exact value it’s receiving from the ECU?
Yes, edit dashboard, select RPM gauges and set the value smoothing to 0 in Look’n Feel.
Our dashboards use quite a lot of smoothing by default as there is so many OBD2 users on which data rate is very slow.
awesome that works great, thank you again for your help!
