Going in and creating global triggers for my steering wheel inputs over canbus, since the readings are taken from analog inputs from resistive type buttons, the readings fluctuate a bit, so for the trigger condition I did 2 entries for if the analog reading is greater or equal to a value and if it’s less or equal to a different value to account for this fluctuation. For the Reset Condition I did the same thing for the trigger to reset when the button is released and the analog value goes back to a resting reading. The first Reset Condition works fine, however when I click on ADD AND, in the next screen it already has the values from the previous Reset Condition, and even if I change the values, it doesn’t save them and the AND condition that is added is like it’s a blank condition. I can then go into that blank condition and make the changes and it saves properly at that point.
Ok, I will try the same sequence if I can find the problem.
Edit: Found the problem, will be fixed in next release.
