Hello guys
I have nissan y61 tb48de with haltech ecu
And im using can to the obd2
And i have issues with speed and gear and voltage is not working
What the solution?
Hello guys
What the solution?
Why do you want to do conversion from CAN to OBD2 when RealDash can read Haltech CAN directly? Using OBD2 will just slow it down and have fewer data inputs available.
So how do I make Real Dash read from haltech can?
Make a connection in RealDash and verify in CAN monitor that you are receiving CAN frames from your ECU.
In RealDash connection settings, press ‘CAN DESCRIPTION FILE’ button and select HALTECH: CAN V2
