Issues with savvy can
Has anyone had issues where you can see the canbus data in RealDash? But, when I use Savvy I can never see any data to help find the ID to create new gauges.
I don’t thing savvy CAN adapter is supported by RealDash.
I think I did not explain this. There is no issues with me seeing canbus data in Realdash that works great (Thanks Devs) The issue is when I’m hooked to the same canbus line on my windows laptop. I’m trying to use Savvy Can to to be able to decode the candata in the car. When I try to create the connection is the savvy can application. It shows connected but It does not show any Data. Didn’t know if anyone has had experience with this and could help.
Change your settings for CAN speed. 500 and 125 mbps are the most common
