Finish next car
all data analog from original connector
input from OBD only MAF, Speed, Volage and Coollant Temp (now present problem: OBD if use sleep mode)
Finish next car
I wonder how much hyundai changed compared to the veloster LOL
sorry - what is “veloster” ???
veloster is a model of hyundai but kia is owned by hyundai so i wonder how much they changed the canbus stuff
i not use CAN (in original connector not present wires with CAN)
i develop and use ADC for this model
and use ODB for few inputs (for save time for calibrate inputs) - i write about before
ahh i wonder if the same would work for my project
Good afternoon Congratulations on the project! I’m from Brazil and I have the same car. I’m new to realdash and would like to change my car’s dashboard. I bought an obd2, but unfortunately it doesn’t provide all the information on the original panel, such as turn signal and fuel level, for example. Could you please recommend a device that I can use to obtain all this information? And about the panel, is some type of Android tablet used?
Okay, I’ll make the project publicly available. It uses only analog signals exclusively. you will have to study a lot, but if you know how to program, then you will certainly succeed! I’ll post it this week.
Thank you very much! I’m a software developer, when I get to this part of the code, I might not have any major difficulties. I think the biggest challenge for me is the issue of taking these analog signals, adapting the panel, among others that appear.
Thank you very much again, I will be following the forum and looking forward to your publication.
https://drive.google.com/drive/folders/1R1lRM3H_RGfabZjp2SXhkHWYkHqBKS6D?usp=sharing
this worked file
also need ADC for RealDash - for example my MCU6 - please see post about Series 5
or any other ADC ////
I still have difficulty with these slightly more technical terms, ADC and MCU6, but I’ll take a look.
Thank you very much for your help!
MCU6 is not a technical term, everything is somewhat simpler, that’s just what I called my project. like the name of my cat is Cat.
ADC - analog to digital converter, that’s how this abbreviation stands for.
Got it, sorry for the confusion.
I took a look there and will try to use these files.
From the photos I saw that your car has more options than mine, here in Brazil.
But I will try to make the most of the information in this file.
Thanks again!
wait can i borrow this dashborad file for my kia sportage
Can it be a .rd file because I need to transfer it via Android Bluetooth transfer as a single file?
