I have a number consisting of 5 bytes that add up. But Realdash doesn’t seem to understand such large numbers. Because I don’t get the right result. What should I do?
Try removing your conversion as it is not required when you tell RealDash to read 5 bytes from data and conversion is not doing anything than byte placements.
Still, it seems odd that odometer uses 5 bytes, as it requires 8 bytes to store in memory, and 4 bytes can already display more than 4 billion kilometers. Are you sure you need to use 5 bytes? Maybe you can try to read 4 bytes and disregard the highest byte as you will likely never surpass the 4 billion kilometers hold in first 4 bytes.
