I have linkecu g4+ connected by USB when I want to import the LINK ECU data: DI 7 speed to see if I have map 2 activated I can’t find that signal but in the ecu it is used, the same as 8. any solution
[image]
[image]
Is it connected with CAN or direct Link ECU protocol? If using direct Link ECU protocol, I would suggest to update to a CAN connection. Link themselves are no longer supporting the direct USB protocol on their newer devices, and I do not know if their tuning software allows any customization for the data stream. Probably not.
Thank you very much, I will have to use a USB cam adapter to send more data than through the USB of the G4+ ecu itself.
