Hi.
I recently replace my old ecu by a new one. Link g4+ xtreme replaced by link g4x xtreme. I use a custom xml file and seed studio can analyser.It was working great with the g4+ but not so great with the g4x. Is there something different that i need to do to make realdash work like before.
“Not so great” is a bit vague. Need more info what is wrong.
To my understanding they should work the same with CAN connection, assuming that CAN output for the ECU is configured with same settings.
Hi
Thanks for the reply. I copied the exact can setting i had in my g4+ into my new g4x. Use the same xml file and now map boost ignition angle. Every analog not working. Digital works.
