Good morning ,
This is for information, I will explain my problem to you:
I installed Realdash on my tablet with Canbus / USB Everything works very well, I have successfully configured all the settings, it reacts well, I added analog outputs (Temp Sensor/pressure oil/pressure fuel) I can access it on the computer on the ca Calculator reads them well, but impossible to read them on Realdash, I modified a dashboard to add them, I was in the parameters to enter the values selected in the ECU it does not work Doesn’t work, I saw that you could choose the Volt analogy It doesn’t work…, how to do it, thank you.
