Merry Christmas everyone,
I have installed Armbian Bookworm 23.11.1 on my Rock5b. The connection to RD should be established via Serial/USB.
RD is installed in version 2.3.4.
The vehicle only has ODBII, unfortunately many interesting data are not available there.
The analog vehicle data such as indicators / lighting / oil pressure / speed / temperatures etc should therefore be recorded via Teensy 3.5 and sent to Rock5b via USB (not via GPIO!).
- What is the difference between RealDash_CAN.ino and RealDash_CAN_2way.ino?
- Which type of connection should I select in RD in my case - connection via CAN or OBD?
After selecting Serial/USB (regardless of whether the connection is via CAN or OBD), 2 entries are displayed in RD:
/dev/ttyFIQ0
/dev/ttyS6
The Rock5b has 4 USB ports (2 x black, 2 x blue).
The first two are currently occupied by the keyboard and mouse. -
which entry do I have to choose - and which USB port is that on the Rock5b?
XML import:
- does the XML file have to be imported again after each change?
Greetings
