I have Realdash on both my computer and my android head unit in my car. I created a dash on the computer and saved it to a flash drive. When I try to import or load the file from Realdash on my head unit, it says ,“no app can perform this function”
It can’t be the size. I tried loading a much smaller file that was only KB in size and received the same message. Also, as noted before, I tried adding a background image in edit mode of a preloaded dash file and received the same message. It seems that if I try to load any external file to Realdash when using the android head unit, I get the same error.
I would if I could, but when I tried to attached the .rd file here it said invalid extension. I then tried to zip the file and attach it and it said the file was too large. This file size is only 547 KB.
Did you mean to allow realdash to have permssions to access the files on the android head unit? If so, I thought I gave full permission for real dash to do that. Is there a certain setting I should change? Please let me know and sorry for the confusion.
This is not true. I work with win10, after that I adjust it to android. Everything works.
Topikstarter does not even bother to reset the file to check how to help him? Maybe she’s worried that we will combine the idea?
