So ecu is been bench tested the PW1 reading doesn’t match the reading from the maxxecu. Data value was around 65.3
I change the conversion (V0.01) changed to (V0.001) and it’s now matching the value MaxxECU is putting out at around 13.5 but is that the correct way to fix it?
That is a correct way, thank you for pointing that out! I will also update the bundled XML.
Awesome thank you
