Maxxecu street no oilpressure, temp or fuelpressure
I just connected realdash to my maxxecu street via usb cable Samsung S21 Phone.
Rpm is fine, battery voltage, coolant temp map etc.
But oil-pressure, -temp and fuelpressure does not show any readings. Input sources is set at ecu/inputs, with oilpressure etc.
Connections on the maxxecu (ain 1, 3, 4 ) are as far as i see configured as what they are in Mtune.
What am i missing out??
Regards
If you go to ā€˜Settings->Application->Debug’ and open Debug Data View, do you see your AIN values on any of the tabs?
Thanks a lot!
I found the values under ā€œecu specificā€ named ā€œuser AIN1(x)ā€ -3 and -4!!
Next dilemma is the pressures is sent in Kpa. And the dash is set at Bar.
How do i convert ?
I tried to write ā€œĆ·100ā€ in guage math but that didnt change a thing.
Must say this was amazing support, payed my subscription yesterday, now i get full support, lol :+1::+1:
I think i solved it by typing ā€œv/100ā€ in math guage :smiley::+1:
hey , i have the same issue , i get no oil preassure reading , im running a bosh pressure/temp combined sensor on a maxxecu street , i cant figure out how to find/map it
thanks
With engine running, go to ā€˜Settings->Application->Debug->Debug Data View’ and see if one of the User AIN values correspond to your engine oil pressure.
