ME221 / 442: Missing analog inputs?
Hello everyone!
I’ve got a Motorsport Electronics 221 PnP ECU in a fairly standard plug and play setup. I am currently trying to get Realdash to actually show some data (Fuel level) from the ECU.
What I’ve done (ECU Side) is send a signal to Analog Input 5:
Input (V) Output (L)
0.046 50
0.074 47
0.110 44
0.163 40
0.224 36
0.274 33
0.311 30
0.347 27
0.388 24
0.468 20
0.559 16
0.646 12
0.730 8
0.805 4
0.857 0
This corresponds to the fuel level of the car in Litres, which I have set as Spare Analog Input 1 (so Analog Input 5 maps to Spare Analog input 1).
I have setup Realdash to connect via USB to my ECU via the standard driver at 230400 baud.
When trying to map my fuel level to this Spare Analog Input 1, I can see that this option is simply not available at all. I am unable to select anything like that from the ECU at all.
How am I supposed to connect the fuel level to the data from the ECU?
If that is of any help, I am also the creator of (the currently very much WIP) ME221 Cross app, so if you need some specific information about what gets sent from the ECU itself, I can provide that.
Hey I do understand this is very niche, but I am really on the fence of buying RealDash unless I can figure this out, I am planning on using it ad a dash replacement and this is absolutely my current biggest gripe
First, verify that RealDash is receiving your analog input correctly:
  • Go to ‘Settings->Application->Debug->Debug Data View’
  • On ‘Custom’ section, do you see your analog input value, and does it correspond to your fuel level?
I would love to do that, and in fact I had even tried by looking older posts, but unless you have Realdash premium It seems you cannot do this.
True, Full version or My RealDash subscription is required to use Debug Data View.
