The following problem appeared in an update. Realdash no longer reads speed data from Megasquirt Box, all other data is correct. With the same computer and the same connection, Tunerstudio software shows the speed information correctly. The settings tested all three engine driver options Hardware Win10, dashbox, and mega3 connected via USB cable. What to do?
- First thing to try is to re-import the ini file, maybe it has been updated?
- What sensor sends your vehicle speed from Mega? Try to add new text gauge and link it to ‘ECU Specific->Your VSS sensor name’. If this new gauge will read correct speed, you can map it as speed sensor in ‘Settings->Units & Values->4th page’
Reinstalling the ini file helped, thanks for the good advice
