Dear all, first of all I have to say what an awesome app!! Really looking forward to creating a bespoke digital dash for my mk6 transit van but I’m having a problem connecting, I know transits have a ford protocol as I use forscan with my proscan WiFi obd adapter (which works fine but is more diagnostic than visual) so I would love to switch to realdash , my adapter connects to realdash but my problem is below:
I really hope you can help
Many thanks
Simon
Hi , I was just wondering if there is any update or info on my last post re the mk6 transit as I’m trying everything & keep getting the same 'no protocol found ’ I really love the app & really want to use it , would upgrading to the full version male any difference? I’m more than happy to buy it .
Many thanks
Simon
I did find a post with a ford focus that had the same problem which you helped with but the information on what you did wasn’t on the post , I was wondering if this would be worth trying.
Again many thanks
Simon
Free version works the same, as we want users to be able to test the connections before purchasing.
I’m sorry, but I cannot help on this remotely. We would need to get the same vehicle and adapter setup to investigate the problem. Typically these problems require to set the vehicle specific header into init section of the XML, but we do not have an access to vehicle specific PID databases.
I don’t think so. Its quite clear that this vehicle needs a special header to be set in order to communicate over OBD2. I can help build a XML file if someone finds out proper command sequence to read the PIDs.
