Hello
guys. How to make this code connect to Realdash via bluetooth? What can I modify or add to the code? I am using ESP32 Devkit V1 and I am new with Arduino coding. Thanks.
- Name : RealDash_CAN.ino
- Part of : RealDash
- Author : Jani Immonen
- Created : 15.10.2017
- Arduino example sketch of how to use RealDash CAN protocol.
- This example code is free for any use.
- www.realdash.net
// Arduino digital and analog pins
unsigned int digitalPins = 0;
int analogPins[7] = {0};
unsigned int rpm = 0;
unsigned int kpa = 992; // 99.2
unsigned int tps = 965; // 96.5
unsigned int clt = 80; // 80 - 100
unsigned int textCounter = 0;
void setup()
// init serial
Serial.begin(115200);
delay(100);
void loop()
ReadDigitalStatuses();
ReadAnalogStatuses();
SendCANFramesToSerial();
// just some dummy values for simulated engine parameters
if (rpm++ > 10000)
rpm = 500;
if (kpa++ > 2500)
kpa = 10;
if (tps++ > 1000)
tps = 0;
if (clt++ > 230)
// all values in frame are handled as unsigned values. To have negative values,
// offset actual value and write corresponding conversion to xml file imported to RealDash
clt = 0;
if (textCounter++ > 4000)
textCounter = 0;
delay(5);
void ReadDigitalStatuses()
// read status of digital pins (1-13)
digitalPins = 0;
int bitposition = 0;
for (int i=1; i<14; i++)
if (digitalRead(i) == HIGH) digitalPins |= (1 << bitposition);
bitposition++;
void ReadAnalogStatuses()
// read analog pins (0-7)
for (int i=0; i<7; i++)
analogPins[i] = analogRead(i);
void SendCANFramesToSerial()
byte buf[8];
// build 1st CAN frame, RPM, MAP, CLT, TPS (just example data)
memcpy(buf, &rpm, 2);
memcpy(buf + 2, &kpa, 2);
memcpy(buf + 4, &clt, 2);
memcpy(buf + 6, &tps, 2);
SendCANFrameToSerial(3200, buf);
// build 2nd CAN frame, Arduino digital pins and 2 analog values
memcpy(buf, &digitalPins, 2);
memcpy(buf + 2, &analogPins[0], 2);
memcpy(buf + 4, &analogPins[1], 2);
memcpy(buf + 6, &analogPins[2], 2);
// write 2nd CAN frame to serial
SendCANFrameToSerial(3201, buf);
// build 3rd CAN frame, rest of Arduino analog values
memcpy(buf, &analogPins[3], 2);
memcpy(buf + 2, &analogPins[4], 2);
memcpy(buf + 4, &analogPins[5], 2);
memcpy(buf + 6, &analogPins[6], 2);
// write 3rd CAN frame to serial
SendCANFrameToSerial(3202, buf);
// build 4th frame, this is a text extension frame
// only send once at 1000 loops
if (textCounter == 0)
SendTextExtensionFrameToSerial(3203, “Hello RealDash, this is Arduino sending some text data”);
else if (textCounter == 1000)
SendTextExtensionFrameToSerial(3203, “Tomorrow’s forecast: Lots of sun and 30 degrees centigate”);
else if (textCounter == 2000)
SendTextExtensionFrameToSerial(3203, “Now Playing: Insert your favorite song info here”);
else if (textCounter == 3000)
SendTextExtensionFrameToSerial(3203, “Message from Arduino: All systems running at nominal efficiency”);
// this is required for RealDash to ‘catch-up’ on ongoing stream of CAN frames
Serial.write(serialBlockTag, 4);
// CAN frame payload
Serial.write(frameData, 8);
void SendTextExtensionFrameToSerial(unsigned long canFrameId, const char* text)
if (text)
const byte textExtensionBlockTag[4] = { 0x55, 0x33, 0x22, 0x11 };
Serial.write(textExtensionBlockTag, 4);
// text payload
Serial.write(text, strlen(text) + 1);
