Multiple instances of RealDash
I run Realdash on an Android head unit to show a few gauges of interest. Each time the vehicle is started Realdash starts in the background. When the ignition is turned off the head unit is powered off without the Realdash app being closed. I end up with multiple copies of the app. I looked in settings but can’t find how to stop Realdash starting on Android power on. I’m happy to start it manually when it’s required. Is there a setting to prevent auto startup ?
Actually, this should not be possible as RealDash prevents multiple instances on Android system. Also, RealDash cannot control how it is launched, so there is nothing app itself can do about it.
Okay, thaanks for that. I will investigate Android settings or other causes.
