I have gauges that are still accessible in Edit mode, but which remain permanently invisible.
I have this for image gauges and for Text gauges.
I’ve tried playing with all the parameters in Look & Feel but nothing makes them reappear. I’ve also changed the source in Input Values but no better result.
Is there anything else I can try to make them appear again?
It’s a pain if I have to recreate them all from scratch.
Thanks for your help
Some things that may cause this:
- You have actions that set gauges invisible
- The color for blend, text: opacity is set to 0
Okay, I think I’ve figured out how the problem occurred.
I had a Container with different Gauges inside.
This Container was faded with a Trigger.
I extracted some Gauges of this Container
and moved them to another Page.
There was now no way to make them reappear.
By including them again in the Container and making the Container reappear (with a Trigger), I was able to recover them. To extract them again, but this time they’re visible!
It would be nice to be able to make Gauges that have been faded with a Trigger reappear.
Yes, currently you just have to use a Trigger to make them visible again.
