Hey all, had an issue with my Khadas VIM3 mainboard so I reflashed Android 9 back onto it
However now I am unable to log back into My Realdash account via the Realdash app. Error just states MyRealdash : OFFLINE LOGIN NOT ALLOWED.
I cant seem to find any other errors while searching, I have a paid copy of Realdash and it was working fine on the old install, There doesnt seem to be any Debug infomation, And yes I am currently connected to Wifi, App downloaded via Play store and can log into the MyRealdash page via Chrome on said SBC.
Should add that I just installed realdash on my windows laptop via the same network the Vim3 is connected to and it installs and connects to realdash fine.
Solved it, I had previously entered the credentials and was attempting to re-enter the password.
After Clicking on the email address field I noticed that my the cursor defaulted to the start of the field not the end (after the email)
While the email address was visable I dont believe it was actually there, Entering no email address into that field yielded the same result as my previous attempts.
Entering the email address in again populated the field and I was able to login
It has been confirmed that 2.4.2 version shows this offline error message if you enter wrong credentials when logging in for the first time. Will be fixed for next release, as this bug does not affect logging in with correct info.
I had the same issue, I was about to make my first post and wasnt too thrilled to make it negative.
My account signed out on a restart after turning off intro’s to test something. Then opened it back up and it would not log back in. I tried to follow guides provided nothing worked. Confrimed I had internet, did a speed test, went to web pages nothing. Updated password on MyRealDash nothing, logged out an back in. Locked the device with an issue, and it said failed to find device. Tried it on another that worked, it said the same message.
Then decided to remove the device and log back in, and it started working.
I had someone else i know screenshot the same issue the other day, which how i found this post. I have uploaded a screenshot showing that everything “SHOULD” have been functioning properly.
Again, in my case I had to remove the windows 10 device, and log back in on the app
Getting the same problem here : Raspberry pi installed in car unable to login despite me triple-checking password etc and resetting password and able to log in on phone and laptop… Cannot type on the raspberry pi without a VNC connection to my laptop, so had connected to laptop and re-entered username and password like 10 times. Why does it need to be logged in anyway, as I don’t always plan to have hotspot connection to the car. Don’t want to reinstall, as I’ve only had it installed a month, and it sure will happen again. HELP!!!
This might help or not, but I believe with a RealDash subscription you are limited to the number of devices you can be logged into. Sign in on the computer and see if you can remove an old device, then try again.
What is the time delay for having to log in again. My car radio is always offline. I don’t even have a smart phone. I use a portable wi-fi device for necessary login.
Ok, and wouldn’t it be possible to set it according to the subscription date and time. Example, I will start every day 5 times, so after 10 days it will require verification ? For example, according to the date that can be retrieved with GPS
