hi, I would like to ask you to add a new action to the action, such as copying a variable to the clipboard. The meaning of the action is that in the selected sensor, a number will be written to a specific variable in the action, and this number can be copied, which greatly simplifies the development of graphical interfaces. Thank you.
Your wording is a bit ambiquous. Do you mean an action that copies the current value of a selected input to the clipboard, or an action where you enter a fixed number/text to copy? Could you give an example of how you would use it when building a dashboard?
hi. I mean exactly copying the current value of a variable to the clipboard.For example, I create a table of triggers using an XML file. I have both a Realdash and an XML document open at the same time. I connect the climate control panel on the table and connect it to Realdash via the Can protocol. The climate sends me packets for each changed action. They don’t mean anything in the way we’re used to, they’re just a set of binary code and instructions.And so I output these few bytes into one long decimal number, and write this number into a trigger in my XML document.my routine is that I do it with my hands and I can make a big mistake if I enter the wrong sign.I could just create a button In Realdash, assign it an action that copies the current value of the Variable in the specified sensor. And using CTRL+V, I would paste it into XML. Do you understand what I’m talking about?
